rinse-raisin
etthink 发表于 2023-1-12 05:27:45 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
rinse
Make sure you rinse all the soap out.
一定要把皂液冲洗干净。
to remove dirt, etc. from sth using clean water only, not soap; to remove the soap from sth with clean water after washing it 指用清水冲洗、清洗、冲掉皂液:
You can also make raisin scones.
你也可以做葡萄干烤饼。
7929帖子
