词汇与表达:connote-imply-infer-implicit
etthink 发表于 2023-1-6 22:07:31 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
connote
If a word or name connotes something, it makes you think of a particular idea or quality.
The term 'organization' often connotes a sense of neatness. organization
这个词常常让人想到整洁。
imply
记忆技巧:im 加以… + ply 重叠,折叠 → 加以重叠表达 → 暗示〔表面一层意思,背后一层意思〕
Do not confuse imply and infer. If you imply that something is the case, you suggest that it is the case without actually saying so. Rose's barrister implied that he had married her for her money. If you infer that something is the case, you decide that it must be the case because of what you know, but without actually being told. From this simple statement I could infer a lot about his wife. Note that some English speakers use infer with the same meaning as imply, but this is considered incorrect by careful speakers.
不要混淆 imply 和 infer。imply 指不加以明说, 但通过暗示表明某事为事实:Rose's barrister implied that he had married her for her money (罗丝的律师暗示他当初娶她是为了她的钱财)。infer 表示在没有被明确告知的情况下, 根据已知信息推断某事是事实:From this simple statement I could infer a lot about his wife (从这一简单的陈述中我能推断出关于他妻子的很多情况)。注意:某些英语使用者把 infer 与 imply 等同使用, 但讲究字句的英语使用者认为这种用法不妥。
plex, plic, ply= to fold 重叠, 折叠
accomplice n. 同谋
ac 加强 + com 共同 + plic 重叠,折叠 + e → 共同聚集在一起〔做事〕→ 同谋
complex adj. 复杂的
com 加强 + plex 重叠,折叠 → 全部重叠起来 → 复杂的
complexity n. 复杂性
complex 复杂的 + ity 具备某种性质,状况 → 复杂性
complicate v. 弄复杂
com 加强 + plic 重叠,折叠 + ate 做,造成,使… → 一再重叠 → 弄复杂
complication n. 混乱,复杂
com 加强 + plic 重叠,折叠 + ation 行为,过程,状态,结果 → 混乱,复杂
complicity n. 同谋关系
com 加强 + plic 重叠,折叠 + ity 具备某种性质,状况 → 聚集在一起〔做事〕的关系 → 同谋关系
comply v. 同意
com 共同 + ply 重叠,折叠 →〔观点〕共同叠在一起 →〔彼此〕同意
duplex adj. 双重的,双倍的
du 二 + plex 重叠,折叠 → 二次重叠 → 双重的
explicate v. 解释
ex 出 + plic 重叠,折叠 + ate 做,造成,使… → 把重叠的东西理出来弄清 → 解释
explicable adj. 可以解释的
ex 出 + plic 重叠,折叠 + able 可…的 → 可以解释的
explicit adj. 明白的;直爽的
ex 出 + plic 重叠,折叠 + it →〔说话〕不啰嗦的 → 直爽的
implicate v. 牵连;暗示
im 加以… + plic 重叠,折叠 + ate 做,造成,使… →〔说话〕加以重叠 → 暗示
implication n. 连累;含蓄
im 加以… + plic 重叠,折叠 + ation 行为,过程,状态,结果 → 连累;含蓄
implicit adj. 含蓄的
im 加以… + plic 重叠,折叠 + it → 重叠表达 → 含蓄的
imply v. 暗示;意味
perplex v. 使复杂;迷惑
per 自始至终 + plex 重叠,折叠 → 始终重叠 → 使复杂;迷惑
pliable adj. 易弯的;柔顺的
pli + able 可…的,能…的;具有…性质的 → 易折叠的 → 易弯的
ply n. (绳子等)股
ply v. 往返于
plywood n. 胶合板
ply 重叠,折叠 + wood 木材 → 木材重叠 → 胶合板
replica n. 复制品
re 一再 + plic 重叠,折叠 + a 表名词 → 重叠原物 → 复制品
replicate v. 复制
re 一再 + plic 重叠,折叠 + ate 做,造成,使… → 再重叠〔一份〕→ 复制
reply v. 回答
re 回 + ply 重叠,折叠 →〔把问题〕叠回去 → 回答
supplicant n. 恳求者
sup 下 + plic 重叠,折叠 + ant 表人 → 折叠膝盖〔的人〕→ 恳求者
supplicant adj. 哀求的
etthink 发表于 2023-1-10 20:36:55 | 显示全部楼层
The doctor gave an implicit answer.
医生给了一个含蓄的回答。
7929帖子
