写作:论文使用的词汇
etthink 发表于 2022-4-1 13:51:36 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
一切由lemma来:http://www.etthink.com/thread-283231-1-1.html
(1) Definition(定义)------a precise and unambiguous description of the meaning of a mathematical term. It characterizes the meaning of a word by giving all the properties and only those properties that must be true.
(2) Theorem(定理)----a mathematical statement that is proved using rigorous mathemat-ical reasoning. In a mathematical paper, the term theorem is often reserved for the most important results.
(3) Lemma(引理)----a minor result whose sole purpose is to help in proving a theorem. It is a stepping stone on the path to proving a theorem. Very occasionally lemmas can take on a life of their own (Zorn’s lemma, Urysohn’s lemma, Burnside’s lemma,Sperner’s lemma).
(4) Corollary(推论)-----a result in which the (usually short) proof relies heavily on a given theorem (we often say that\this is a corollary of Theorem A").
conclude
(5) Proposition(命题)-----a proved and often interesting result, but generally less important than a theorem.
(6) Conjecture(推测,猜想)----a statement that is unproved, but is believed to be true (Collatz conjecture, Goldbach conjecture, twin prime conjecture).
(7) Claim(断言)-----an assertion that is then proved. It is often used like an informal lemma.
(8) Axiom/Postulate------(公理/假定)a statement that is assumed to be true without proof. These are the basic building blocks from which all theorems are proved (Eu-clid’s ve postulates, Zermelo-Frankel axioms, Peano axioms).
axiom
英 [ˈæksiəm]     美 [ˈæksiəm]
For if there were infinitely many axioms, they could not all be written out.
因为如果有无限多个的公理,我们就无法把它们全写出来,
(9) Identity(恒等式)-----a mathematical expression giving the equality of two (often variable) quantities (trigonometric identities, Euler’s identity).
(10) Paradox(悖论)----a statement that can be shown, using a given set of axioms and de nitions, to be both true and false. Paradoxes are often used to show the  inconsistencies in a awed theory (Russell’s paradox). The term paradox is often used informally to describe a surprising or counterintuitive result that follows from a given set of rules  (Banach-Tarski paradox, Alabama paradox, Gabriel’s horn).
paradox
记忆技巧:para 旁边;外 + dox 教,观点 → 观点边有观点 → 自相矛盾
矛盾的人(或事物、情况);
似非而是的隽语;  悖论;   悖论修辞
'More haste, less speed' is a well-known paradox.
“欲速则不达”是人们熟知的似非而是的隽语。
7929帖子
