英语语法学习记录
发表于 2021-4-1 22:27:47 | 显示全部楼层 |阅读模式
语法:
音:英语的读音规则,常见字母及字母组合读音
学习读音规律,推荐使用https://www.merriam-webster.com/
词:知道词的来源及构词方法,能解释
短语与句子:
段:
篇:
从句的引导词真让人崩溃
I'm afraid he's nore of a talker tha a doer,which is why(不能用that)he never finishes anything.(只是因为前面有which后面就不能用that吗,这是一个表语从句吗)
最近做测试,总是有语法问题,以后将问题记录在这里。
1、为什么bird是个体名词,而cattle是集体名词。
2、英语为什么不说直接打某人的部位:http://www.qiexing.com/post/hitsb.html
见到一个句子you hit her in the face,为什么不直接说:你打了她的脸 you hit her face
介词神烦,看下面的介词
You could simply say:"I'm going to put you on hold for a second" 你可以简单说:您得稍得一会,不能说please wait for a second?
put这个词
        Put sb. out
        × 让某人出去
         使不方便;打扰
        这个用法是美式英语中常用的俚语,在口语中表示“打扰”的含义。
        例如:
        I don't want to put you out.
        我不想给你添麻烦。
        类似于:
        I don't want to bother you. /I don't want to cause you any trouble.
A:I hope I didn’t put you out. I’m Li Ming with Sunshine Business Corporation.
希望没打扰您,我是阳光公司的李明。
        1)put sb on :让某人接电话
        这是一个电话常用语:比如你接了一个电话,对方要找你的同事,你就可以说 wait a moment please, I'll put him on. 等一下, 我让他接电话。
        2)put sb through:接通电话
        put sb. through (to sb.)"A接通(给B的)电话"的意思。
        如果说"请接通销售经理",就是:Please put me through to your Sales Manager.
        3)put up or shut up :要不你就去做,不然你就给我闭嘴
        有些人总是喜欢耍嘴上功夫, 光说不练, 对这种人不耐烦到极点的时候, 你就可以这样说哦!不过发狠过后还怎么相处呢?想来想去,也许还是自己put up or shut up更简单啦。
3、suspicious of sb/sth
4.I shall never meet ___daughter of Mrs.Brown's.
A.the B.that C.such D.which
正确答案是B.
有所指,所以that
5.She wants to go shopping,but she has hardly___.
A.any money B.some money C.money D.no money
正确答案是A.
hardly any几乎没有,固定用法
6.He climbed up into the tree and ___all the fruit within reach.
A.took B.picked C.fetched D.held
pick fruit摘果子,固定用法
7.I won't pay $20 for the coat;it's no worth ___.
A.all that much B.that all much
C.that much all D.much all that
正确答案是A.
that much是”那么多“,all形容that much,位置应在前面.
8.It is required that all would-be employees___citizens of this country.
A.be B.are C.is D.will be
正确答案是A.
require 从句接动词原型,固定用法
9.He might do it,and so_____.请问该选哪个?为什么,
A.might his best friend
B.his best friend may
C.will his best friend
D.his best friend should
答案:A
这里的动词是情态动词 might,其他的助动词 may/will/should 都不符合题意
翻译:他可能做这件事,他最好的朋友也可能做
表示“ 某某也一样”用 so + 助动词+ 主语
 楼主| 发表于 2021-4-30 17:43:53 | 显示全部楼层
表音文字关心于语言本身,语素文字关心于文字层面,其实都有得失。
比如英语的“music(音乐)”一词,它的词源来自于古希腊掌管艺术的缪斯女神(Μουσαι),由此衍生了“mus”词根,相当于汉字的偏旁部首。Muse(灵感)、museum(博物馆)、amuse(v.娱乐)、amusement(n.娱乐)都是由“mus”词根衍生。
再比如mov、mob、mot三个同源词根,表达的是“移动”的含义。因此move(移动)、movie(电影,移动的图片)、mobile(可移动的)、mobility(流动性)、motion(n.运动)都是由此衍生。
汉字独特性,或许就是汉字能保存这么旧的原因所在。拼音文字可能是从口头语言发展而来,是语言的记录。这就表示要理解文字就必须了解语言。换句话说文字受制于种族和语言的差异,口语发音可能每个地区都有明显的差异,即便是相同的语言,通过地理隔离可能演化成两种不同的口语文字。而象形文字不同,象形文字是会意文字,针对某个字,每个种族都可能有自己不同的口语发音,但却都能会意通晓他的含义,这样的文字就对种族语言没有过多的要求。无论口音如何语言如何,识其文即可会其意,这样的语言有利于多民族的融合。PS我的一个猜想:象形文字可能早于拼音文字。因为象形文字依靠人类简单的视觉的认知能力就可以完成,而拼音文字要等到人类具有语言系统以后才产生。从进化的角度讲,语言系统应该晚于视觉认知系统。
声音是语言的第一位,文字是记录该文字创造之初时的语音。汉字作为语素文字,单位太大,分析起来比较困难。但是探究词源,声音又是至关重要的。古代一直喜欢望字生义,因为不懂声韵学,常常把形声字当会意字来解,现代民科也常干这种事,十口心是为思,心心皆为思社稷。这种当作趣话助记汉字不失为一种方法,但正儿八经地当词源解就太过荒谬了。清儒段玉裁就发现,要解字,先求声,声通则义明。结果训诂学得到了很大的发展。但是由于汉字是语素文字,他们当时能做到的极限也就是将韵部分好,具体的发音细节是得不出的。就像巅,天,顶三字,若是不知其声,从字形上打死也想不到会有联系。至于汉字的稳定性,那是因为中国长期大一统,加上典籍丰富,文字稳定而已。要是秦始皇没统一全国,任由原先六国自己的文字各自发展下去,文字差异之大会远远超过想象。如果秦始皇时期汉字是音素文字,那么流传到今天,写法和当时不会有多大区别,和现在的语音脱节非常严重,比如五,可能写作nga,读作五。文字正字比较早的语言都有这种情况,比如和汉语同源的藏语,记录的就是一千年前的中古藏语读音,和现代拉萨音脱节严重。阿拉伯语,蒙古语都有这种情况。
拼音文字缺点有很多,随便列举几个:1.只知道读音不知道一个东西的源含义,文字本身附带的信息极少;2有时候字母的读音或词汇拼读规则会改革,这种改革通常是全面整体的改革,毕竟也就那么几个字母,会连累所有的词汇改变读法,比移风易俗还狠;3.其实是1的次生影响,因为文字本身附带的信息量少,如果出现文化断层,后代即使掌握先人典籍,也很难复活曾经辉煌的文化,运气好拼读规则改变不大还能对着典籍拼出几个还口头流传的词汇对应上,但也仅限于此了。4.对于新生事物造词能力低下,推广缓慢;5.一些字母推广范围广,使用相同字母的文化圈经常会出现词汇异花授粉的现象,尽管看起来差别不大,但异文化词汇的拼写和构建词汇的规则和自身文化是不一样的,当这种词汇累计到一定数量,甚至会改变原有的语法。
所以英语词和词的意义关联,主要靠语音实现。
中文里,“天”字看似和“人”相关,但在语音层面实际上和“巅”、“顶”有联系。正是因为汉字“字形”一直占据解释“字义”的统治地位,导致研究汉字“字音”关联和流变发展缓慢。
比如卷、蜷(蜷缩身体)、圈(画圆)、埢(螺旋形山脉)、淃(螺旋水流)、鬈(头发卷曲)这些字,看似“卷”是一个声符,但实际上主导这些汉字字义的不是“虫、囗、土、氵、髟”等形符,而恰恰是“卷”。因为语言先于文字,所以这些字字义在语音层面和卷同源。
 楼主| 发表于 2021-4-15 18:14:40 | 显示全部楼层
can could be able to
  三个词都是能够,但是当我们讨论的事情与说话是同时进行的时候,不能用be able to
    例: Watch me, Mum; I can stand on one leg. (一边说一边站,不能用I'm able to stand on one leg.)
    动词被动式前不能用 be able to
    例:Films can now easilly be streamed online. (不能用Films are now easily able to be streamed.)
    想要表达知道如何完成的意思时不能用be able to
    例:Can you cook? (不能用Are you able to cook?)
    过去时中谈论一个成就而非普通能力时,比起could更倾向于用be able to
    例: She swam strongly and was able to cross the river easily. (游过河是一个特定的成就,不能用could cross)
    过去时的否定句中用could比be able to更合适
    例:I tried to get up but I couldn't move.
    和感官动词feel, hear, see, smell, taste,以及跟思想有关的动词believe, decide, remember, understand连用时,用could
    例:I could remember the crash, but nothing after that.
    在单词all和词组the only thing/place/time之后表示唯一能做用could
    例:All we could see were his feet.
    表示几乎没有发生,特别是和almost, hardly, just, nearly连用,用could
    例:I could nearly touch the ceiling.
    讨论理论上的可能性用could,讨论事实上很大概率会发生用can。
    例:It could be expensive to keep a cat. (猜测如果有只猫,可能会烧钱)
    It can be expensive to keep a cat. (事实上有人养猫就是很费钱)
    如果是理论或现实中不可能实现的情况用can't,不能用couldn't
    例: There can't be many people in the world who haven't watched television.
    暗示将来的事情有很大可能性发生用can,暗示某事不太可能发生或者抱有怀疑态度用could
    例:We can stay with Jake in Oslo. (会在一起)
    We could stay with Jake in Oslo. (如果Jake在的话就可以待一起,说明人不在)
    过去时里有权利在任何情况下做某事用could或 was/were allowed to,但是在过去某个特定情形下被允许做某事,用was/were allowed to,不能用could
    例:Anyone was allowed to fish in the lake when the council owned it. (或者...could fish...)
    Although he didn't have a ticket, Ned was allowed to come in. (不能用...could come in)
    过去时的否定句中,可以用couldn't或wasn't/weren't allowed to 表示在任何情况下都不被允许
    例:I couldn't/wasn't allowed to open the present until my birthday.
 楼主| 发表于 2021-4-28 09:18:15 | 显示全部楼层
come to 的用法:come to 后接名词、数词、代词或不接任何词,它的意思是:
1)、谈到, 涉及到
When it comes to physics, he is a complete stranger.
谈到物理, 他完全是个外行。
2)、表示“合计,总共”,与 amount to同义。如
How much does the bill come to?
帐单上共多少钱?
3)、表示“开始被…所认识,被…所记起。”突然想起(无被动式) ,如
Suddenly, the words of the song came to me.
突然间, 我想起这首歌的歌词来。
4)、 发生(在某人身上), 降临于(某人)。如
Happiness will come to you as long as you are after it.
只要你追寻它, 幸福会降临于你。
5)、 恢复知觉, 苏醒过来。如
After three hours in the hospital bed, he began to come to.
躺在医院床上三个小时后, 他开始苏醒过来。
come up to
1.move near;approach;reach the height of接近;向…走来;达到…高度
A man came up to me and asked for a match.一个男人向我走来,要求点个火。
The water is coming up to the bank.水涨到与河岸相平了。
2.equal;reach相当;达到;与…匹敌
Your work did not come up to the expected standard.你的工作没有达到预期的标准。
He will come up to our expectations in his new job.他在新的工作中不会辜负我们的期望。
This picture does not come up to the one you showed me yesterday.这幅画没有你昨天给我看的那一幅好。
3.have the expected ill effect or result on对…产生预期的坏结果
Excessive drinking and smoking will come up to him.过量地喝酒抽烟,他是要吃苦头的。
这里应该用come up to 表示来到的意思。
 楼主| 发表于 2021-4-4 20:21:03 | 显示全部楼层
一、副词的位置:
1) 在动词之前.
2) 在be动词、助动词之后.
3) 多个助动词时,副词一般放在第一个助动词后.
注意:
a.大多数方式副词位于句尾,但宾语过长,副词可以提前,以使句子平衡.
We could see very clearly a strange light ahead of us.
b.方式副词well,badly糟、坏,hard等只放在句尾.
He speaks English well.
二、副词的排列顺序:
1) 时间,地点副词,小单位的在前,大单位在后.
2) 方式副词,短的在前,长的在后,并用and或but等连词连接.
Please write slowly and carefully.
3) 多个不同副词排列:程度+地点+方式+时间副词.
注意:副词very 可以修饰形容词,但不能修饰动词.
改错:(错) I very like English.
注意:副词enough要放在形容词的后面,形容词enough放在名词前后都可.
 楼主| 发表于 2021-4-12 19:42:46 | 显示全部楼层
be going to与will的区别:
1、be going to与will两者都可表示将要发生的事、将要去做某事.
2、be going to 表示近期、眼下就要发生的事情,will 表示的将来时间则较远一些。
3、be going to 表示根据主观判断将来肯定发生的事情,will表示客观上将来势必发生的事情。
4、 be going to 含有“计划,准备”的意思,而 will 则没有这个意思。
5、在有条件从句的主句中,一般不用 be going to, 而多用will。
“I was going to do the washing, but we would run out of washing powder.”
 楼主| 发表于 2021-4-14 22:23:37 | 显示全部楼层
May be the best of things.也许是最好的东西
About to start school again so....又准备要开学了
Find the hope in the unexpected 在意料之外去发现希望
 楼主| 发表于 2021-4-14 22:52:27 | 显示全部楼层
Speaking is 50% language skills and 50% mindset!
Do worries ever stop you from speaking?
I hnow,But you weren't there anyway. 我知道,反正你也没有去。
You are your worth enemy.你是你自己的敌人。
That's exactly what I think.我的确是那样认为的。
Remember what that one is?记住了那个没?
Would you like to pay now or shall I charge it to your room.您是现在付款,还是记在您的房费里?
Do you ever wish you were just like erveyone else?你可曾希望 自己和其它人一样?
stand by to fire on my order.听我的命名,开火。
I think I need one more cup of coffee.我想再来一杯咖啡。
I'm not sure I'm ready for that.我还没有准备好。
 楼主| 发表于 2021-4-15 18:05:07 | 显示全部楼层
need doing=need to be done(有被动的意思)
need to do
how 和 what 都用来引导感叹句,它们有什么区别呢?how 在这里是一个副词,用来修饰形容词和副词;而 what 是用来修饰名词的,所以即使是同样的句子,how 和 what 引导的句子结构是不一样的.请看下列例句:
(1) 多美丽的一朵玫瑰花呀!
How beautiful a rose it is!
What a beautiful rose it is!
(2) 多晴朗的天气呀!
How sunny the weather is!
What sunny weather it is!
(3)这些学生是多么聪明呀!
How clever the students are!
What clever students they are!
 楼主| 发表于 2021-4-15 18:09:57 | 显示全部楼层
You are here,There is nothing I fear. 你就在我身边,我无所畏惧。
get pale表示“.苍白了”,强调已经苍白了.
go pale 表示“变..苍白了”,强调变化的过程
She ________ pale at the news of the accident in the coal mine.
A. feared
B. went
C. found
D. felt
 楼主| 发表于 2021-4-15 18:15:38 | 显示全部楼层
It can be like random thoughts.它可以是随机的想法。
what's up with him 他怎么了
not if you go that way. 如果你走那条路,肯定不能
 楼主| 发表于 2021-4-16 08:08:45 | 显示全部楼层
if you don't look good,we don't look good.我们的光彩来自您的风采
I've had it up to here.我受够了
 楼主| 发表于 2021-4-28 08:02:59 | 显示全部楼层
get start with 应当是一个固定搭配
Let's get started with the spring related idioms 让我们开始学习与春天相关的习语吧
 楼主| 发表于 2021-4-28 08:03:02 | 显示全部楼层
Do you ever say things like this
你有没有说过这样的话
Questions like:What is the passive voice?例如:什么是被动语态
 楼主| 发表于 2021-4-28 08:25:17 | 显示全部楼层
The next part is with pictures,right?这个with 为什么不能去掉?
 楼主| 发表于 2021-4-28 08:26:26 | 显示全部楼层
I feel sick,I wish I hadn't eaten so much cake.
I feel sick.可知,这是说明自己现在很难受,那么后面希望的内容是过去要是没有吃那么多蛋糕就好了,是对过去事实的假设,所以用过去完成时.
 楼主| 发表于 2021-4-28 08:30:58 | 显示全部楼层
There's a lot to see in Rome.
为什么要用不定义,a lot 后面省略了什么吗?
 楼主| 发表于 2021-4-28 08:36:52 | 显示全部楼层
你们俩认识多久了?两年了。
How long have you known each other ? -------For two years.
Have you known each other long?
两种问法有什么区别
 楼主| 发表于 2021-4-28 08:40:01 | 显示全部楼层
be polite of
 楼主| 发表于 2021-4-28 08:41:45 | 显示全部楼层
Should you desire I can provide character references.若您需要,我可以提供推荐信。
 楼主| 发表于 2021-4-28 08:44:50 | 显示全部楼层
a once in a lifetime opportunity.一生仅此一次
 楼主| 发表于 2021-4-28 08:47:31 | 显示全部楼层
the dollar has risen against the yen,and so has(这个对吗?和前面对称?is..did) pound.
 楼主| 发表于 2021-4-28 08:48:14 | 显示全部楼层
But above all of this,I wish you love,但最重要的是,我希望你能找到 真爱
另一个翻译是
But above all of this, I wish you love希望你欣赏我做的一切,并為你带来快乐
哪一个正确
 楼主| 发表于 2021-4-28 08:51:15 | 显示全部楼层
Can we always be this close forever and ever?我们可以永远这样亲密吗
And time's forever frozen still.而且时间也永远停留在最美的一刻。
 楼主| 发表于 2021-4-28 08:54:02 | 显示全部楼层
The clounds above passing by 云在头顶掠过
When it all turns around 当一切翻天覆地。
Memories of you flood in(大量涌进) between my rhymes.我的故事都是关于你的。
对你的回忆涌进了我的旋律
You've been part of everthing I've been through.
A good idea flashed upon me. 我脑海里突然闪出一个好主意
  The river is in flood
 楼主| 发表于 2021-4-28 08:59:04 | 显示全部楼层
stop doing 停止做某事
stop from doing 阻止做某事
 楼主| 发表于 2021-4-28 09:00:13 | 显示全部楼层
I guess your promises were hot air
But we were worth it
So, I hope life treats you kind. 我希望生活善待你
 楼主| 发表于 2021-4-28 09:03:01 | 显示全部楼层
lead on         怂恿; 教唆; 鼓动;
 楼主| 发表于 2021-4-28 09:04:41 | 显示全部楼层
Superman got nothing on me.超人也不及我
got nothing on sb  某某不能和sb相比
 楼主| 发表于 2021-4-28 09:08:48 | 显示全部楼层
And end this heartache I'm pained to feel.结束这让我难熬的心痛。
I've been torturing my self night and day.日日夜夜,我饱受折磨。
 楼主| 发表于 2021-4-28 09:11:38 | 显示全部楼层
perhaps easier and also effctive is immersion.可能更简单也有效的方法是沉浸式学习
 楼主| 发表于 2021-4-28 09:14:29 | 显示全部楼层
wild mild正好相反
GMT+8, 2026-1-7 04:13
